C
crossride
While installing Coolermaster Hyper 6 cooler on EPoX 8KDA3J (AMD Athlon
64, Socket 754) motherboard I broke a component which interfered with
cooler support frame.
This much I know about it.
Marking: WW1 / 46 (WW1 along the longer side and 46 rotated 90 degrees,
most likely 46 is a lot number)
Package: SOT23-3
ID on board: D39 (also D6 is same)
Connections: Lead 3 goes to ATX 20-pin connector lead 8 (PWR-OK, aka
POWER GOOD), lead 2 sinks into any of the middle layers, lead 1 can be
followed on the picture at
http://velo.clubbers.ee/~erikr/D39/P1010002.JPG.
Measured resistance on leads of the another, non-broken one near the
CLEAR CMOS jumpers (position D6), any combinations between leads gave
readings of 600K or more up to infinity. Measurements done with Fluke 73
multimeter.
No lead connected with ground.
Have been searching on the net for a week but still no luck.
Based on electrical measurements cannot be a diode, transistors are
marked with Q on schematics, colleagues have suggested Zeners, field
transistors, JFETs, voltage supervisors.
WWx markings seem to be exceptionally rare, only real match with marking
is
http://www.smd.ru/files/upload/1245/ru/bat54.pdf
,see p2, marking section.
Near matches are http://www.marsport.demon.co.uk/smd/smdw.htm.
E-mail to EPoX support has given no reply.
Could anybody help to figure out the component, either original or if
knowing exact purpose of it, suggest a replacement.
I'd rather like to save the board that cost me 100 Euros than throw it
away.
Thanks in advance.
Package: SOT23-3
multimeter.
is
away.
Thanks in advance.
