Have you located the datasheets for these (the 1SS106 is
here)
If you have the datasheets and you're asking for replacement parts then a link to the datasheet will help us help you.
Otherwise, the first trick is to find the datasheets, even if that means you just have to point them out to us if you can't decide on a replacement.
It's also possible that the actual use of these components may influence the choice of replacement part. For example if the supply voltage is 12V then it may not be strictly necessary to look for a part with a 90V reverse voltage rating.
