hello,
I have a young 3 year old son with mild autism who loves to play with water for hours at end. I'm planning to build a nice water table that will keep him occupied this summer.
I pretend to be very handy with tools, but honestly I can use some help from "the internets" with the electronics here:
I want the water to be flowing constantly (as he mostly likes to catch it in a cup) so I'm planning to place a small pump under the table that will pump the water back to a spout on top.
since the table is outdoors, and I don't want to mix water with high voltage, I was planning to use a 500mA 12V battery pump such as this one:
http://www.amazon.com/submersible-W...WIR0/ref=sr_1_3?ie=UTF8&qid=1334608903&sr=8-3
I will place the pump and battery in a sealed box under the table, but I'm assuming that even in the worst case scenario that the battery will somehow short to the water table 12V will not give my kid a shock. is that correct?
2- ideally, I want to set the pump in such a way that by pressing a button, it will turn on, and after a set time (say 5 minutes) it will go off, until someone pressed the button again. (otherwise the thing will be left to run overnight...)
is there a timer that I can buy and place in line between the battery and pump?
How can I go about building one?
cash is short, so I'd like to keep this on the cheap.
I have experience with a soldering iron, and I've build some circuits before, but I'm afraid I forgot most of what I knew. but I'm a fast learner!
I understand that perhaps I might be asking for a lot. I'm relying on the kindness of strangers to help me for nothing in return but gratitude!
thanks for reading,
Alex
thanks for reading,
Alex
