Playback on camcorder fuzzy
Discussion in 'Electronic Repair' started by Tino I, Jul 11, 2005.
  1. Tino I
    Tino I Guest
    I have a problem with my JVC GR-SXM540 S-VHS-C camcorder.Playback of any
    recording on the camera itself gives a fuzzy picture. If I record something
    with the camera and play it back on a VCR the picture is fine. The camera
    has only been used a few times but is past warranty. Cleaning heads did not
    fix it. From what I've read on the net, this has happened before with this
    particular model. Any ideas what it could be?
  2. Cleaning heads did not fix it.
    I had this with the same model. Normal cleaning won't do. use a VERY
    fine
    sheet of emery paper dipped in Fairy liquid.
  3. NSM
    NSM Guest
    Very droll - not!
  4. Guest
    If emery paper doesn't do it, then use a bastard file or grinding
    stone.... then you can RUIN the heads and drum even faster.
    electricitym
