Plasma TV/stupid question.
Discussion in 'Electronic Repair' started by [email protected], Mar 9, 2007.
  1. Guest
    I just got this rather large set in for repair. There is no stand and
    therefore no way to really support this thing to troubleshoot it. I
    worked on one in the past that had a stand so it was supported when I
    took the back off, but this seems impossible to deal with. What do
    most people do to support these things when working on them. I'd sure
    hate to see it fall over. Thanks, Lenny Stein, Barlen Electronics.
  2. Guest
    Somewhat depends on size and brand, but we have two ways, depending on
    what we need to do. First, we have a large-area roll-around we put a
    4" thick foam pad & blanket on, then lay the set face down on it. This
    works very well for most. For testing and alignments after repair, we
    built another padded roll-around that we can put the set upright on.
    This also works well (except we made it a bit too close to the
    ground). Hope this helps.
    Steve
    Pearsons Electronics
    Spokane, WA.
  3. Guest
    So for testing and alignment I take it that there is also a padded
    surface on the bottom and then does the set just kind of lean back
    onto this padded 90 degree upright as well? Basically a table top with
    a full 90 degree back is what I'm picturing. Lenny
  4. Guest
    You got it.
    Steve
  5. Arfa Daily
    Arfa Daily Guest
    Friend of mine who does a lot of these built a simple bench top lay-back
    frame from 22mm copper plumbing pipe and fittings, picked up at his local
    hardware store. It has two bars which stick out towards him at the bottom.
    These are at 90 deg to the main frame, which lays back at probably 30 deg.
    When repairing the item, it lays forward on the frame, with the top tilting
    away from him at 30 deg. This is a perfectly good position to work on it,
    and has the advantage that it is still sufficiently 'upright' to allow the
    picture to be seen in the mirror at the back of the bench. When the set is
    repaired, he simply turns it around on the frame for soak testing, with the
    screen facing out into the workshop.
    Arfa
  6. Guest
    I like the ideas. This first repair I just laid on its face padded and
    supported on its frame but for future repairs I'll probably build a
    type of stand mentioned. Thanks to everyone. Lenny.
