Plasma or LCD?
Discussion in 'Electronic Basics' started by Rodney Kelp, Feb 7, 2005.
  1. Rodney Kelp
    Rodney Kelp Guest
    What's the latest poop on wide screen hdtv's? I heard Plasma's burn out
    fast. LCD's seem to cost more now than plasma. I think the opposite was true
    last year. I"m looking for about 42' to 48' widescreen.
  2. Bob Myers
    Bob Myers Guest
    Assuming you mean 42" or 50" (I don't think there are any
    standard products at 48" diagonal), you are most likely going to
    be looking at a plasma set; LCDs larger than 37" are not yet
    very common (although they ARE starting to come onto the
    market). LCD remains more expensive than plasma in those
    ranges where they do compete, but the problem with "burn-in"
    on plasmas is greatly reduced on the latest models, to the
    point where I personally would not worry much about it.
    Bob M.
  3. Art
    Art Guest
    That is unless he is considering a Rear Projection LCD or DLP set. That may
    be what he is referring to? Bob is correct, the flat screen LCD sets are
    limited currently to size. And they are moderately expensive! Also the newer
    plasma seta are "coming of age" regarding burn-in and other plaguing
    problems. Select on your personal preferences and budget.
  4. ILYA
    ILYA Guest
    Hi All!
    Do You know some about new generation display panels?
    Its based on array of small LEDs.
    I expect that it will have very good climatic parameters, brightness,
    contrast and low consumption relatively LCD with highlight lamps...
    But LCD has many problems on low temperature weather :eek:(
