PIR LED 12V light circuit recommendations wanted.
Discussion in 'LEDs and Optoelectronics' started by Sidecar Bob, Dec 28, 2021.
  1. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    I bought some HC-SR501 type PIR units to experiment with. Knowing nothing about this technology I assumed that if I use a 12V power supply I could run a 12V LED light from it but that didn't work. I did some research and checked the spec sheet again and learned that regardless of the supply voltage the PIR unit has 3.3v (TTL) output.
    I did a bit more research and it indicated that I could use a transistor to drive the LED, which would have been easy for me to figure out 30-40 years but but over the decades I've forgotten a lot.
    Can someone please recommend a simple circuit for this?
  2. Bluejets
    Bluejets
    5,251
    1,101
    Oct 5, 2014
    Simpler to use a logic level mosfet like an IRLZ44N........
    Here is a circuit using a IRL540N ......same same....5v supply replaced by your 12v naturally.
    R1 about 100R....R2 around 10k....common the negative on both supplies.
  3. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    I've never worked with mosfets (or any other kind of fet) before but I have a pile of regular transistors so I'd rather use what I have if I can.
  4. Martaine2005
    Martaine2005
    3,664
    998
    May 12, 2015
    What LED light are you wanting to use?
    Can you post the specs.
    Martin
  5. Bluejets
    Bluejets
    5,251
    1,101
    Oct 5, 2014
    Well then, like Martin says, you're going to have to supply some more details.
    Circuit I showed would work straight up, transistors will need some working out based on your reply.
  6. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    It is a generic eBay/China side marker light similar to these. I have low voltage (12V DC) lights on the side of the garage that run dusk to dawn and I bought a bunch of these a few years ago to mount inside the garage and connect to it (I figured at the time that it cost less to run half a dozen of these all night every night than it would to turn on the main lights for a minute a few times per week).
    https://www.ebay.ca/itm/384327257796
    That eBay listing doesn't give any power or current specs and to be honest I have never measured the current to one of them. The closest I've come was plugging the 12V supply in with my plug in power meter and comparing as I added them to the circuit; At the 110V AC mains plug each one increased the power by 0.5W.
    I also mounted 4 of them on the bottom of the cabinet in the basement kitchenette to light up the counter, powered by a 12V 1A supply and the power meter said 0.5W for just the supply and 2.5W for the supply + 4 lights.
    I figure that works out to about 42 mA per light but I can connect one to a supply and confirm that when I am in the shop later today and let you know.
    For this project I need to use 1 of these lights but it would be nice if I could add another later on.
  7. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    How about that. The actual current I measured with the 12V supply I want to use and the light I've already mounted in the box (next to the sensor) is only 26mA (measured with 2 meters to make sure).
  8. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    Nothing?
  9. Cirkit
    Cirkit
    141
    10
    Oct 28, 2015
    Which transistors do you have?
  10. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    I'm not in the shop right now so I can't list them all but I have a bunch that are equivalent to 2N2222.
  11. Cirkit
    Cirkit
    141
    10
    Oct 28, 2015
    The specifications for the HC-SR501 seem to suggest it will operate from 12V. So you can connect the TTL output via a 1k resistor to the base of your transistor and drive a fair few of your LEDs in parallel.
  12. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    The HC-SR501 will definitely work with a 12V supply. When I was trying to figure out what was going on I had one connected to the 12V supply I want to use for this with a 3mm LED + resistor on the output and left it running on the end of the bench for a few days
  13. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    I'm in the shop now and looking at my bin of transistors. I have
    - a bunch of "generic" TO-5 types with numbers like CK913, CK914, 2n414, RCA 40595, a lot that aren't marked and a bunch with IT ID GA stamped into them.
    - some TO-46 marked 267819
    - some TO92 marked 70C 7427 and 70C 7411
    - an RS-2021 brand new in Radio Shack package (says 2N2907 on the back of the card but the card shows a TO-18 and this is a TO-92)
    - a few other plastic/epoxy types with numbers like 636ge, 886GE, 2N3393, GE5128 and an assortment of unmarked ones (for some reason I have it in mind that some of these are equivalent to 2N2222)
  14. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    I came across this circuit that looks promising. He posted a link to a video of it turning on LEDs on his stairs. What do you think?
    https://i.stack.imgur.com/7tT4P.jpg (The thread asked how to add an LDR so the lights wouldn't come on in daylight but that doesn't matter for my project).
    [​IMG]
  15. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    No opinions?
  16. Sidecar Bob
    Sidecar Bob
    44
    4
    Dec 19, 2021
    I just realized that the link in post #14 is to the drawing, not where it came from. Here's the correct link
    https://electronics.stackexchange.c...-controlled-by-pir-want-to-add-ldr-to-project
    I also realized that the transistor's terminals are not labelled. Based on other similar circuits I see online I think it is safe to assume that the emitter is connected to the negative line.
    Once I removed the switch, indicator LED and 7805 that I don't need it looks like this. Is this all I need to do?
