Pioneer XV-HTD510 drawer help
Discussion in 'Electronic Repair' started by Mike, Jun 26, 2005.
  1. Mike
    Mike Guest
    The disc drawer opens then shuts and I'm not able to puit a DVD in it or
    get one out. Sometimes it works but mostly it doeasn't work correctly.
    I had a Sharp DVD player and it did the same thing years ago so someone
    must know of a fix.
    Mike
  2. Jerry G.
    Jerry G. Guest
    There is no support from the manufactures for service for these drives.
    They are considered disposable, especialy when considering value of the
    labour cost, and the setup to be able to service these.
    The only thing you can do for yourself, is to open the drive unit, and
    see if there is anything that you can mechanicaly fix yourself.
    If you have some basic service skills, you can look to see if there are
    any loose connections, or if something is mechanicaly jaming., or if
    there are any visible cold solder connections.
    Jerry G.
  3. Mike
    Mike Guest
    I should let it be known that this is a home theater system that's about 3
    yrs old.
  4. DO_NOT_PAY_ANY_ ATTENTION to Jerry G's useless generic advice.
    Yours is a home theater dvd-receiver, not a 5 1/4 form factor dvd drive for
    a computer.
    It is EASILY fixed by a knowledgeable technician. In your particular case,
    there is a noisy switch underneath the drawer. It can be cleaned or replaced
    by a KNOWLEDGEABLE technician.
    It is NOT a doit-yourself job for most people.
    Mark Z.
