Pioneer SD-P452 Big Screen
S
Shoreline Electronics
Text pasted from WinSTIPS 2.0
http://www.ServiceSoftware.com
PIONEER SDP452
Common Problems On Convergence Board:
Osage Tv On The 2 Series (Sdp402 / 452 / 502)
Q755/Q765/Q775/Q785//Q795 2sd1276a, Q756/Q766/Q776/Q796 2sb950a,
R458/468/478/488/455/456 6.8-1w, R465/466/475/476/485/486/495/496 2.7 Ohm 1w
PIONEER SDP452
Common Problems On Signal Board
Tuner Axf1021, Ic101 Pa0028
PIONEER SDP452
Crt'S Weak; To Boost
High Tech Audio Video Kux1c Chassis
This Set Is Very Difficult To Boost The Crt Voltage. It Can Be Done By
Changing D641 Zener From 5.1v To 5/6v 1/2w On Fly Pcb
PIONEER SDP452
Horiz/Hv Problems On Deflection Board:
R360 3.9 Ohm 1/2w, Ic554 On3161-Q, Q584 2sd1555, R283 6.8-2w Audio Ic
Ta8200ah
PIONEER SDP452
Pix & sound inop. Osd ok seemed to be in signal panel
[email protected]
Found leaky Q624 & D646 on power-deflection board in 5v supply
PIONEER SDP452
Vertical Problems On Deflection Board:
Q577 2sd1276a, Q578 2sb950a, Q579 2sd1276a, R181 1 Ohm 1w, R182 1 Ohm 1w,
R186 1 Ohm 1w
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
"If you push something hard enough it will fall over."
Fudd's First Law of Opposition - Sir Sidney Fudd
