Pioneer Radio Problems
Discussion in 'Electronic Repair' started by tlars, Feb 13, 2007.
  1. tlars
    tlars Guest
    I have a Pioneer DEH-425 radio and i am experiencing problems.
    Everything works but no power goes through to the speakers. I
    installed the radio and did not put in the voltage regulator piece
    that is in the power wire. it worked for aprox. 2 months and then this
    happened. Any help would be apreciated.
  2. First check your speakers to be sure they are not blown (open) for some
    reason, then check all your speaker connections for the correct
    continuity with no shorts or open connections.
    Then check all of the other wiring behind the radio. They should all be
    soldered or crimped and covered with something permanent like heat
    shrink tubing. Twisting wires together and covering with electrical
    tape is not the way to go.
    If all connections are correct then remove the stereo and reurn it if
    it's under warranty.
    Otherwise you will need to have it serviced.
    I don't think that was a regulator you left out, possibly it was a noise
    filter. Either way you should always connect things exactly the way the
    instructions and diagrams say.
