Pioneer LD-S2 LaserDisk drawer problem
  • Thread starter William Sommerwerck
  • Start date
W
William Sommerwerck
I had to pull out my LV player to compare the LV of "Roger Rabbit" with the
BD. This player is almost 25 years old, and is getting mechanically cranky. To
wit...
The motor-driven drawer closes, but won't open unless I tip the player
forward. * Moving the drawer manually reveals substantial friction, possibly
due to deteriorated lubricant.
I downloaded the service manual from "manual buddy". (Yes, the name is
suspicious-sounding, but it was only $5, and the scan was excellent.)
Unfortunately, the manual doesn't discuss mechanical servicing (other than
alignment).
Before tearing into the unit... Two questions...
Thanks in advance.
* It weighs over 30 pounds and is built like a tank.
"'We already know the answers -- we just haven't asked the right questions."
-- Edwin Land
N
N_Cook
wit...
alignment).
Thanks in advance.
-- Edwin Land
Is the friction just trying to turn a gear-train , the wrong way. Do you
hear the drawer motor spinning? Most likely perished drive band between
first and second pinion, next likely cracked first pinion if plastic
W
William Sommerwerck
Is the friction just trying to turn a gear-train, the wrong way. Do you
first and second pinion, next likely cracked first pinion if plastic.
The motor is audible, both when loading and (trying to) unload. There is no
obvious indication that anything is broken. If the drawer is blocked when
unloading, it automatically retracts, as it's supposed to.
It is probably a lubrication problem. I need to know what lubricant to use.
If worse comes to worst, I can call Pioneer and ask for advice.
Clean all the rails and use Lubriplate on them. Also, I think this one used a drive belt. The belt may be slipping as it takes a bit to get hte drawer started. Check these first and update this thread. In the meantime, I'llook up my old records. I haven't seen one of these in a long time.
Dan
W
William Sommerwerck
a drive belt. The belt may be slipping, as it takes a bit to get the drawer
started.
I saw a reference to drive belts.
Check these first and update this thread. In the meantime, I'l look up my
Thanks. I'll get to it later today.
W
William Sommerwerck
Getting to the loading mechanism requires removing at least two large circuit
boards. On the chance I might damage them (physically or electrically), I'm
not going to remove them -- especially as I don't have a proper work area.
However...
The service manual shows that the tray can be lubricated along its tracks,
which are easily accessed when the tray is "out". The lubricants used are
described as
Floil GB-TS-1
Jig No. GYA-008
Grease G-397
Jig No. GYA1001
I was able to find both at Encompass Parts Distribution and PacParts:
http://www.encompassparts.com/item/5569346/Pioneer/GYA-008/Silicon_Oil_Pl750
http://www.encompassparts.com/item/5569350/Pioneer/GYA1001/Lubricating_Oil_Pdm50
They're not cheap. Anyone know any substitutions?
There is a loading belt and a synchro belt. Both appear to require major
disassembly to access.
Thanks.
D
Dave Garrett
wit...
alignment).
Thanks in advance.
30 pounds? Closer to 75. I used to think my CLD-97 was heavy, until I
got a recently-serviced LD-S2 last year. Built like a tank is an
understatement.
alt.video.laserdisc is pretty dead these days, but you may want to post
this question in the LaserDisc Database forums:
http://forum.lddb.com/ (you have to register to gain access to the
forums)
http://www.lddb.com (main site)
W
William Sommerwerck
to post this question in the LaserDisc Database forums:
You have to register to gain access to the forums.
Thanks.
Since my previous post, I checked the gearing on the disk tray. It was
COMPLETELY DRY. There's no sign there had EVER been ANY lubrication at all.
Perhaps the right lube will fix it. If anyone has suggestions for
less-expensive versions of the "official" Pioneer lubricants (at least one of
which is still used, in BD players), please let me know. Thanks.
M
Mark Zacharias
Thanks.
all.
of which is still used, in BD players), please let me know. Thanks.
Belts have been mentioned but I would like to add my vote. It's the tray
loading belt. 20 years old and a big heavy tray? You're lucky it still works
at all!
Mark Z.
W
William Sommerwerck
GC Electronics products includes several lubricants, and I found
that their calcium stearate-based Luberex product is a very good
general purpose light duty grease. The last tube I bought was ~$4
for 2 fl oz/56 gms.
Much gracias for the suggestion. I don't need to fix the unit "immediately". I
can visit the GC site, poke around, and ask a few questions. Thanks.
W
William Sommerwerck
at all!
Closer to 25 years. Perhaps the moderate PNW climate helped preserve it.
The service manual shows that there are at least two belts, one of which
drives the loading tray, the other the tray door. Both are buried deep within
the machine. I don't wish to open it if I don't have to.
