Pioneer HTZ121 DVD Sound Issue
keithuboy
Aug 11, 2021
6
Aug 11, 2021
6
My Pioneer HTZ121 DVD is behaving erratic. With all 5.1speakers connected there is sound from all speakers for some time, if i increase the volume then the sound stops. After keeping it off for about a week it works normal again.
Without the 8 Ohm main speaker ( Only 4 surround plus base bin) it works at any volume.
The area above the amp card is getting very hot when 8 ohm main speaker is connected.
Is it a speaker or amp fault?
Harald Kapp
13,700
13,700
Try another speaker. If the issue persists, it is likely a fault of the amplifier. If the issue goes away, it is the speaker.
Could also be an issue with the cable's insulation, check the cable and all connections.
keithuboy
Aug 11, 2021
6
Aug 11, 2021
6
I now realised that it is not a speaker issue. If i select DVD, it says loading or stop or no disc. After this, i think the system hangs and then nothing play... This happens erratically. Sometimes the DVD functions normal.
Harald Kapp
13,700
13,700
Could be an issue with the power supply. Show us a clear picture of the area that gets hot.
