P
Phil Bowser
Today I spent far too much time today trying to diagnose a problem I
have never seen before (On any proj. TV, for that matter...) I thought
maybe it was just strange enough that somebody has run into it before...
Set powers up, displays picture and sound from all inputs. Usually
when cold (very first turned on) pix is correct on screen, then begins
shifting to the right (takes about 10 - 30 seconds.) During the transition,
the picture squiggles a little like a poor AFC lock on an old directview
zenith. Once the picture is shifted about 3 inches to the right (leaving a
black blanking bar on the left 3" of the screen) it stabilizes, and will
play indefinitely in this condition. Convergence is correct, RASTER is
correct, On Screen display is correct, just the video "slides to the
right" - if you have the OSD called up while picture is shifting, you can
see the video sliding the the right, while the OSD remains in its correct
position. Since the raster and geometry are correct, I have ruled out a
deflection problem. I 'scoped all B+ supplys from Defl./P/S pc board, and
they are correct & clean. I soldered any connection that looked cracked on
the P/S/Defl PCB and convergence, as good preventive maint. and replaced
several lytics that took excessive heat on P/S/Defl. regardless of the fact
that they read good for ESR and capacitance. I have also sprayed freeze on
the system control micro, jungle, and Horiz. osc. resonator - unit does not
return to normal...
It looks like there is a phase shift in the video versus the deflection,
but I haven't been able to tell why, since the flyback pulses are clean,
etc...This one's got me stumped. Anyone seen this before? Any bulletins on
this? (I don't get to work on as many Pioneers as other brands...)
return to normal...
