Pinhole B&W camera probs
Discussion in 'Security Alarms' started by Guest, Feb 28, 2007.
  1. Guest
    Guest Guest
    I bought a IR illuminator for use with a color/B&W pinhole camera, It
    doesn't pick up much better than in total darkness. Are their different IR
    illuninator freqs? The IR is supposed to work with any camera.
    Remove the 2 to respond off list
  2. Pogo
    Pogo Guest
    Depending on the camera and IR source, You need quite a bit of I/R power to
    reach beyond 60ft. Pin Hole cameras are not very effecting beuond 60 ft. If
    what you are doing is beyond this range you need to upgrade your hardware.
  3. Guest
    Guest Guest
    The illuminator I have for this is rated for 120' The lux on this camera is
    ..1 so it's probably unsuitable for this
    Remove the 2 to respond direct
  4. Bob Noble
    Bob Noble Guest
    That lux rating is for use with light. With IR illumination, it doesn't come
    into effect.
    The ir will only work in black and white mode, as in color, there is an ir
    filter in place.
    There may also be a setting in the camera software that puts the camera in
    low light mode, which may remove the ir filter that is used in color mode.
    You may also need to go in the camera's setting and adjust the brightness
    control.
    Dig deeper.
  5. Guest
    Guest Guest
    It's made by plex here's the specs on it. It switches from color to b&w in
    low light if it helps figure this out. I sure can't at the moment
    PX-208S
    a.. New! Smaller than any Coin Camera.
    b.. Image sensor: Sony 1/3-inch super HAD CCD
    c.. TV system: PAL/NTSC
    d.. Pixels:
    PAL: 500 (H) x 582 (V)
    NTSC: 510 (H) x 492 (V)
    e.. Horizontal resolution: 420 TV lines
    f.. Minimum illumination: 0.5 lux/F1.2
    g.. S/N ratio: > 50dB (AGC off)
    h.. Back light compensation: center measure, on/off switch
    i.. Auto white balance: center measure, auto trace white balance
    j.. Electronic shutter: 1/50 - 1/100,000 sec.
    k.. Internal synchronized camera system
    l.. Lens: pin-hole, broad angle
    m.. Video output: BNC 1.0Vp-p, 75 ohms
    n.. Power supply: DC 12V 300mA
    o.. Operating temperature: -20 deg. C to +50 deg. C
    p.. Storage temperature: -40 deg. C to +60 deg. C
  6. Bob Noble
    Bob Noble Guest
    I don't see anything in the specs on weather the ir will work or not.
    The camera is very small so may not be able to move an ir filter. My
    understanding is the cams that work with ir, work in black and white and
    have to move the ir filter out of the way. They work in zero lux, because
    you are now working with the ir lights. The lux spec given for the camera is
    for light, not ir. IR works in zero lux. It doesn't need light. Get it? :O)
    Just for grins, have you gone into the camera's settings and tried turning
    up the brightness setting?
    The ir filter may let enough through it to see if you try turning this up.
    As I remember, this is something I had to do with one that had built in ir
    illuminators, so you should check this out if you haven't.
    Are you feeding this to a computer?
