Pin out SN29730N
Discussion in 'Electronic Repair' started by J M Goodey, Nov 12, 2003.
  1. J M Goodey
    J M Goodey Guest
    Can anybody please help?
    Pin out needed for Texus SN28730N
    Not found on Texus site.
    Believed to be SN74221N but with pinouts in a different order.
    TIA for you help
  2. Tom Wright
    Tom Wright Guest
    Is it used in a TV?
    TIA for you help
  3. J M Goodey
    J M Goodey Guest
    The message <3fb4aba7$>
    No its the mater Oscillator on an old Farfisa Electronic Organ
    It is a dual multi vib.
    Same as a SN74221 but with pins in a different order.
    Google comes up with nothing helpful.
  4. Uns Lider
    Uns Lider Guest
    It should be possible to work it out.
    SN74221 is 16 pins; is SN29730N also 16 pins?
    You can come up with candidates for GND and Vcc by checking which pins are
    hooked to the power plane.
    Each of the two halves has a true and a complement output. With the circuit
    operating you should be able to see these on a scope.
    The data sheet shows an external resistor from Vcc to each Rext/Cext, and a
    capacitor from each Rext/Cext to Cext.
    The A inputs will be either wired to the controlling circuit or tied to
    ground. The B inputs will either be wired to the controlling circuit or
    tied to Vcc. Uh, unless half the chip is unused, in which case 2A will be
    tied to Vcc and/or 2B will be tied to ground.
    If the CLR inputs are unused they will be tied to Vcc.
    If only a true or complement output is used, then the other one will be a
    no-connect.
    Let us know what you find out.
    -- uns
