N
N_Cook
eg
http://blog.makezine.com/_support.gateway.com_s_MOTHERBD_INTEL_m00264_m00264
This package uses a secondary board , outlined in white square in the above
pic. On the periphery, just about visible in that pic, of this square board
there are traces , approximately 50 to a side. Not all have a corresponding
dot pad. Underlying array is 20 x 20 , not all pinned, and excluding
repeated grounds and power rails , maybe about 4x 50 active pins.
If you remove the lacquer covering, do each of these peripheral traces , go
to each active pin, hidden underneath?
Is there a structure to the order of these linear traces to the subset of
pin array row/col , corresponding to that edge ?
