help.. i managed to do the drumset using parallel port. the problem is, i cant use the piezo properly.here how i do it.
i connect pin2(d1) of the parallel port to the COLLECTOR of the NPN transistor(BC548). then i connect the positive wire of the piezo to the BASE of the transistor. then i connect the ground to the EMITTER of the transistor. I also connect the negative wire of the piezo to the ground.
The problem is, when i hit the piezo,sometimes the PC reconizes the input,sometimes don't. I tested using a switch,it works perfectly.
So my guess is that the voltage of piezo that is giving the BASE is very low.
OR maybe the BASE of the transistor is expecting high voltage than a piezo can give.
so how will i solve this problem? please help me..
