TBadertscher
- Apr 14, 2015
- 18
- Joined
- Apr 14, 2015
- Messages
- 18
If I have a piezo electric actuator that produces 5 mW with one actuation (using the piezo as a reverse generator i.e. applying force creates the voltage rather than applying voltage to actuate) does that mean that 2 actuations would equate too 10 mW. If this is not true, why not?
Let me explain my train of thought so you can correct me where I am wrong. Is this still false when you connect a super cap/battery? I look at a Watt(unit of power) as a joule per second which is a form of energy. Since a piezoelectric device pulses the current(the current is not constant), there is a definitive amount of energy per acuation. Lets say 5 volts and 5mili amps per actuation which is 25 mW. When that energy is stored in the battery, and another actuation occurs; that does not equate to 50mW going into the battery/super capacitor? If not, how can I harvest the energy from each actuation to charge a super cap? Thanks in advance!
