Piezo gas lighter
Discussion in 'Electronic Repair' started by N_Cook, Nov 13, 2009.
  1. N_Cook
    N_Cook Guest
    Self inflicted breakage. They are not made for the damp UK. I thought this
    new one (basic one not butane) I'd winterize before any use proper . Easy to
    take apart , in fact dropped apart, after removing from the steel frame. 2
    separate peizo rods in a plastic open ended cylinder. Central copper disc
    between the rods leads out to the HT tip and steel frame for the return and
    contact at both ends of the rods, one via the steel pressure cam. Added a
    couple of activated silica gel crystals and placed hotmelt glue in each end
    before reinserting the steel disc protector pads at each end. Unfortunately
    I was not thinking about polarity and replaced them back to back and no
    output at all. Redid and working hopefully for a few damp UK years without
    need of replacing. I forgot to note where the ratchetting action comes from,
    when inside. When reassembled wrongly there was no ratchetting, is it a
    relaxation effect within the piezo elements, I saw no obvious toothing in
    the metalwork.
