Piecewise linear diode model?
Ledwardz
Dec 21, 2010
43
Dec 21, 2010
43
hi, I've been asked to draw a piecewise linear model of a diode and state the function of each component in the model.
Am i right in thinking that this would be a diode in series with a resistor from a DC supply?
in which case i presume its silicon (doesn't say) and so has a cut in voltage of 0.7V
which creates a graph with
Id on the y axis
Vd on the x axis
and a curve that stays flat until 0.7v when it rises.
then i presume the resistor will have a large voltage drop across it as well as reducing the current.
and a silicon diode allows current to only flow in one direction
somehow though i figure this is not what the question wants me to do (its worth 6 marks) any ideas?
Thanks, Lee.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
There are several major features of a reverse biased junction that I might try to model.
There are also non-linearity in the forward biased V vs I relationship.
How far do you have to go? Dunno. It all depends on what you've been taught.
Ledwardz
Dec 21, 2010
43
Dec 21, 2010
43
errrrr only been doing electronics for 2 month and that doesn't seem to ring a belI. I did actually find an example where it said draw a piece wise linear but it gave component values so you could work out the current etc...... and again they had just drawn the v to I of the diode but had mentioned that it was to find an approximation and drawn straight lines on the curve then used 1/rf to work out gradient of slope.
what would be the most basic parts you would mention or draw?
Ledwardz
Dec 21, 2010
43
Dec 21, 2010
43
cheers, i think ill just leave it like that example with one sector. they can't expect much more than that tbh we havn't been doing it for very long.
