E
ehsjr
Ouch.krw said:Is there Arsenic in old LEDs?
I think candles flicker because of air flow changes.
So you need an air flow sensor.
Could be done by monitoring the voltage over a heated thermistor perhaps.
More air flow, temp drops, voltage changes.
Come on Michael. Aren't you reading what the warmingists in thisWe have broken the record low for North Central Florida three times
this month. So much for glow-ball warming.
Which brings up the obvious questions... Can one use LED indicators
and be RoHS compliant? Is there a RoHS LED?
Is there Arsenic in old LEDs? Are they RoHS compliant?
Yes, and that flicker apparently masks the 60Hz flicker from the
bulbs.
I can easily see fluorescent flicker if it's close.
If the ballast puts line frequency AC through the lamp, then the ends do
have 60 Hz flicker component. Electronic ballasts usually produce a small
amount of 60 Hz flicker - more if their filter capacitors are insufficient
or defective. I normally do not see 60 Hz flicker from fluorescents with
electronic ballasts, though I do usually see flicker from monitors set to
60 Hz.
- Don Klipstein ([email protected])
Digi-Key has 8,884 items for discrete LEDs <75 mA, and 7,894 of them
are RoHS compliant.
(Actual number of different LEDs stocked is less - most come in at least
2 different forms of packaging, with separate catalog numbers.)
Nearly all red, orange, and yellow LEDs prior to the InGaAlP ones that
came out in the mid or maybe early 1990's have arsenic. One older red
chemistry, having peak wavelength 690, 697 or 700 nm and wide bandwidth,
does not.
Apparently includes:
Lumex SSL-LX20465YD (yellow)
Lumex SSL-LX20465ID (A slightly orangish red - known as "high efficiency
red" in the late 1970's and early 1980's).
At least 11 through-hole red Avago LEDs are currently in Digi-Key's online
catalog, and have wavelengths and brightnesses typical of GaAlAsP (or
whatever it is that Avago calls "AlGaAs"), maybe a few of the dimmer
ones have GaAsP instead.
60 Hz.
I can see flicker from just about any fluorescent tube if the
lighting is just right (wrong?). It usually doesn't bother me too
much but I can see it. 60Hz CRT display flicker makes me physically
ill. I cannot have a display in my field of view set to 60Hz or I
will get ill.
I bought 1000 LEDs for the outside this year. Ick! What horrible
light. I've already bought incandescents to replace them for next
year. The LED strings go in the garbage as soon as the holidays
are over. A waste of $150, but sometimes education costs.
Michael A. said:So the tubes only conduct in one direction? They should have a 120
Hz flicker rate.
60 Hz.
In article <[email protected]>, To-Email-
[email protected] says...
> On Wed, 24 Dec 2008 19:55:24 -0600, "Tim Williams"
> <[email protected]> wrote:
> >80 LEDs (so far; I'm going to whip up another string of 40 yet), a PWM
> >driver (LM393) and an isolated switch running strings off the line.
> >Tim
> Anyone made a synthetic candle flicker using LED's?
> I'm still using NE-2's, but I don't like the effect.
> What is stark contrast... my outdoor icicles are incandescent... my
> star-bursts are white-white LED's. I guess I need to go to all LED
> stuff ?:-(
Keith
will get ill.
The only thing that ever bothered me is having a 72 Hz and a 75 Hz
monitor side by side. It also drove everyone that saw them running
together nuts.
together nuts.
CRT's I presume?That's weird. I have to set these two monitors to different
frequencies (75Hz & 85Hz the only choices above 60Hz) or I get
interference bars walking through the displays. Which raises the
question, how does one get interference bars on two monitors
running from the same display card? Seems to be a stupid design.
CRT's I presume?
Field coil magnetics interfere with each other. BTDT
Your eyes generally try to smooth out the flicker. The beat
frequencies between two displays at different refresh rates causes
that mechanism to fail.
Try forcing both monitors to the same vertical rate.
Why did he commit to 1000 before seeing a sample?
