Picture Tube Specs.
Discussion in 'Hobby Electronics' started by John Ely, Feb 18, 2005.
  1. John Ely
    John Ely Guest
    Hello,
    Does anyone know where I might find data sheets and or pinouts for
    TV picture tubes , specifically the tube in question is a Philips
    A68ESF002X111 made in France probably about 4 years old , Philips Aust.
    while helpful were unable to come up with much. There does not seem to be
    much info. on any CRT's on the internet.
    Cheers John Ely.
  2. KTN
    KTN Guest
  3. Franc Zabkar
    Franc Zabkar Guest
    I can't help you specifically, but one thing you could try is to
    crossreference the pinout to a known one by checking the list of
    adapters for a CRT rejuvenator. For example, this adapter list ...
    http://www.promax.es/pdfs/adap_i.pdf
    .... for this rejuvenator ...
    http://www.promax.es/ing/productos/familias.asp?subfamilia=27
    .... specifies adapter A8 for your CRT.
    A8 can be used with these CRTs:
    http://members.optusnet.com.au/~fzabkar/a8.txt
    - Franc Zabkar
  4. Franc Zabkar
    Franc Zabkar Guest
    I have an Osborne monitor which is a rebadged Philips 4CM8270. The
    parts list states that the CRT is an M36KUT23XX22. This CRT uses the
    same A8 adapter as yours.
    The pinout is as follows:
    5 G1
    6 Green K
    7 G2
    8 Red K
    9 Heater 2
    10 Heater 1
    11 Blue K
    12 N/C
    You should be able to identify the heater pins by testing for
    continuity between them.
    - Franc Zabkar
  5. Franc Zabkar
    Franc Zabkar Guest
    Oops, pin 12 is G4 (Focus).
    - Franc Zabkar
