PICBASIC serial communications problem
Discussion in 'Electronic Design' started by [email protected], Jul 23, 2005.
  1. Guest
    Hi all
    I am trying to communicate with a computer using pic18f4620 in basic
    programming. I am using the hyperterminal to send and recieve
    messages. I am displaying the incoming message onto an LCD screen. When
    I run the code below the LCD screen displays garbage. I am not sure at
    what baud rate this program should be working either. Please help.
    Include "modedefs.bas"
    ' RS232C Serin2 and Serout2 Demo Program
    ' Define ONINT_USED to allow use of the boot loader.
    ' This will not affect normal program operation.
    'Define ONINT_USED 1
    'DEFINE OSC 32
    DEFINE LCD_DREG PORTD 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit (0 or 4)
    DEFINE LCD_RSREG PORTB 'Register select port
    DEFINE LCD_RSBIT 7 'Register select bit
    DEFINE LCD_EREG PORTB 'LCD enable port
    DEFINE LCD_EBIT 6 'LCD enable bit
    DEFINE LCD_BITS 8 'Defines the number of bits wide
    DEFINE LCD_LINES 2 'Sets the number of LCD lines
    DEFINE LCD_COMMANDUS 2000 'Sets the LCD command delay time in
    us
    DEFINE LCD_DATAUS 50 'Sets the LCD data delay in us
    'ADCON1 = %00001111
    ' OSCTUNE = $40
    ' OSCCON = $72
    DEFINE HSER_RCSTA 90H
    DEFINE HSER_TXSTA 20H
    DEFINE HSER_BAUD 9600
    ' DEFINE HSER_SPBRG 25
    TRISB = %00011111
    PORTB = %00000000
    TRISE.0 = 0 'Set PORTE.0 to output
    TRISE.1 = 0 'Set PORTE.1 to output
    TRISE.2 = 0
    TRISD = 0
    TRISC = %10010000 ' Bits 7 & 4 set as Inputs
    PORTC = %00000000 ' All off to start
    PAUSE 1000
    bootupscreen:
    LCDOUT $fe,1 'Clear LCD screen
    pause 500
    LCDOUT "USART TESTING" 'Put up self test display
    pause 500
    ' LCDOUT $fe,1 'Clear LCD screen
    LCDOUT $fe, $C0 'Start of second line
    LCDOUT "THIS LINE IS CRAP"
    pause 500
    ' ADCON1 = 7 ' Set PORTA and PORTE to digital
    ' Low PORTE.2 ' LCD R/W line low (W)
    ' Pause 200 ' Wait for LCD to start up
    'Vars: Tx var PORTC.6
    ' Rx Var PORTC.7
    ' rec var byte[1]
    ' 'rec var BYTE
    'loop: HSERIN [RX, STR rec\1]
    'loop: serin2 rx, 84, [STR rec\1] 'input
    ' IF REC = 1 THEN GOTO loop ENDIF
    'outlcd: lcdout $fe, $94, "RECEIVE = ", STR rec\1
    'HSEROUT ["RECEIVED"]
    ' serout2 Tx, 84, ["RECEIVED = ", STR rec\1] 'output
    ' PAUSE 500
    Rx Var PORTC.7
    rec var byte[1]
    send VAR BYTE
    send="y"
    ' HSERIN {ParityLabel,}{Timeout,Label,}[Item{,...}]
    ' HSERIN2 {ParityLabel,}{Timeout,Label,}[Item{,...}]
    ' SERIN Pin,Mode,{Timeout,Label,}{[Qual...],}{Item...}
    ' SERIN2 DataPin{\FlowPin},Mode,{ParityLabel,}{Timeout,Label,}[Item...]
    ' Hserin 10000, start, [char]
    ' serin rx, T9600, [STR rec\1]
    outlcd: lcdout $fe, 1, "RECEIVE = ", STR rec\1
    serout2 Tx, 84, [send]
    ' SEROUT Tx, T9600, ["RECEIVED"]
    goto loop
