Picaxe Program Variable Help
Discussion in 'Microcontrollers, Programming and IoT' started by Jasper.carpenter, Sep 23, 2019.
  1. Jasper.carpenter
    Jasper.carpenter
    3
    Sep 23, 2019
    I am trying to make a variable increase every time a sensor senses something. I also want a button to reset the variable counter. I have been trying for a while but I still don't quite get it. This is the code I have so far.
    [mod edit: moved to to code box]
    Code:
    #no_data
    start:
    readadc c.0,b1
    readadc b.5,b3
    debug b0
    main:
    b2=0
    sensor:
    IF b1= 1 then b2=b2+1
    endif
    IF b3= 1 then goto start:
    goto sensor:
    I keep on getting syntax error at line 11 before position 15 (IF b1= 1 then b2=b2+1) saying 'Error: Expected a label not the variable B2'
    I have created a loading circuit and plugged the into the sensor, and I have a display but am not sure how to program that either. It would be much appreciated if someone could help me out.
  2. Harald Kapp
    10,993
    2,498
    According to the manual, pages 107/108 it looks like the single line structure can be used with goto or gosub only.
    Use a multiline structure as shown in the manual or e,g, here.
  3. Jasper.carpenter
    Jasper.carpenter
    3
    Sep 23, 2019
    Thanks for that, I got it to work now, is there a way for me to display this on a 7 segment display?
  4. Harald Kapp
    10,993
    2,498
  5. Jasper.carpenter
    Jasper.carpenter
    3
    Sep 23, 2019
    How would you extend this to multi-digit displays, this link only shows for one digit.
  6. Harald Kapp
    10,993
    2,498
    By multiplexing.
