P
Peter
Does anyone know anything about the PIC600 regulator? I'm trying to
understand a circuit I saw and it's used as a 5 volt regulator. Below is a
link to the datasheet that I found, but there doesn't seem to be enough
information on how to regulate the output to 5volts. There is only one
example circuit where they use a 2.5ohm resistor on the output as a load and
it shows 5 volts from the regulator, outside of that, I don't understand it.
The max output states 60 volts I believe so it looks like there is a way to
change the output voltage.
Do I not have the correct datasheet?
http://www.datasheetcatalog.com/datasheet/PI/PIC600.shtml
