PIC18 - eeprom write
Discussion in 'Electronic Basics' started by Randy Day, Dec 31, 2006.
  1. Randy Day
    Randy Day Guest
    This is my first attempt to write to eeprom
    using a pic18f2455. Obviously it isn't
    working. ;)
    Most of it is straight out of the datasheet;
    can anyone point out what I'm missing? Thanks.
    ;write serial number to EEPROM
    ; EEADR initial value is 4
    ; MOVWF EEADR ; Lower bits of Data Memory Address to write
    DECF EEADR ; decrement EEPROM address for ser# storage
    MOVF NIBBLE_TEMP, W ; ser# value to store
    MOVWF EEDATA ; Data Memory Value to write
    BCF EECON1, EEPGD ; Point to DATA memory
    BCF EECON1, CFGS ; Access EEPROM
    BSF EECON1, WREN ; Enable writes
    BCF INTCON, GIE ; Disable Interrupts
    MOVLW 55h ; Required Sequence
    MOVWF EECON2 ; Write 55h
    MOVLW 0AAh ;
    MOVWF EECON2 ; Write 0AAh
    BSF EECON1, WR ; Set WR bit to begin write
    ; User code execution
    BTFSC EECON1, WR
    GOTO $-2
    ; test for write errors (WRERR) would go here...
    BCF EECON1, WREN ; Disable writes on write complete (EEIF set)
    BSF INTCON, GIE ; Enable Interrupts
  2. <snip>
    Randy,
    I am very new to PIC MCUs, but you might want to try the PIC list. Lots of
    folks there who know this stuff.
    http://www.piclist.com PIC/SX FAQ & list archive
    Good luck,
    Richard
  3. Randy Day
    Randy Day Guest
    Richard Seriani, Sr. wrote:
    [snip]
    Bookmarked. Thanks!
  4. Sambo
    Sambo Guest
    Just out of curiosity, what programmer are you using?
    I have built the PIC-PG1 (JDM with 6.2V zener instead of 8.2V),
    always had 90% failure rate with 16F626A now.
    after over a year later can't program the new 18F2320s or the old 16f628s.
    The new IC-PROG(G) I have noticed some strange things so I am loosing faith
    in it too.
    Just about ready to build a parallel programmer and control it from LINUX
    if I could only find some detail info on programming algorithms, in case that
    is available doesn't work.
    Cheers, Sam.
  5. Randy Day
    Randy Day Guest
    I'm using the PicKit 2 from MicroChip.
    It came with a 16F690 as a learner chip,
    but I'm using it now to program 18F2455's.
    I've had no problems at all so far; it
    works great. Then again , mine is a
    hobbyist environment, not day-in-day-out
    use. IIRC, it retails for about US$80.
    It came with a USB programmer dongle,
    a preassembled breadboard, MPLAB and the
    PicKit programming software (Windows),
    lots of tutorial help and code examples.
    Not to mention lots of stuff on the CD
    that I've never even looked at... :)
    One thing I did have to do was download
    a later version of the PicKit software
    (v1.21) in order to program the newer
    PIC18 series.
    Anyone who wants to do in-circuit
    programming with the PicKit 2 should read:
    http://pic18fusb.online.fr/wiki/wikka.php?wakka=PicKit2Header
  6. Sambo
    Sambo Guest
    Maybe I'll finally break down and buy one of those.
    I would be nice to compile and burn.
  7. ===============================================================================
    It is very helpful to have a debugger such as the ICD2, but it costs about
    $150, so might be out of reach for a hobbyist. The software simulator is
    extremely powerful, however, and you might be able to track down your
    problem in that way.
    You can try some of the following code. I am using a PIC18F242. I think it
    works for EEPROM, but now I write to Program Flash Memory, which I think is
    recommended as more reliable:
    EEPROMread:
    MOVLW DATA_EE_ADDR ;
    MOVWF EEADR ; Data Memory Address to read
    BCF EECON1, CFGS ; Access program FLASH or Data EEPROM memory
    BSF EECON1, RD ; EEPROM Read
    MOVF EEDATA, W ; W = EEDATA
    RETURN
    EEPROMwrite:
    MOVLW DATA_EE_DATA ;
    BCF INTCON, GIE ; Disable interrupts
    MOVLW 55h ;
    MOVLW 0AAh ;
    MOVWF EECON2 ; Write AAh
    BSF INTCON, GIE ; Enable interrupts
    ; user code execution
    RETURN
    ;Read a block of data from CODE_ADDR into BUFF_ADDR length BUFF_LEN
    FlashRead:
    BSF EECON1, EEPGD ; Point to Program Flash memory
    MOVFF CODE_ADDR_UPPER, TBLPTRU ; Load TBLPTR with the base
    MOVFF CODE_ADDR_HIGH, TBLPTRH
    MOVFF CODE_ADDR_LOW, TBLPTRL
    MOVFF BUFFER_ADDR_HIGH, FSR0H ; point to flash buffer
    MOVFF BUFFER_ADDR_LOW, FSR0L
    MOVFF BUFFER_LEN, COUNTER ;Initialize byte counter
    READ_BYTE
    TBLRD*+ ; read into TABLAT and increment
    MOVF TABLAT, W ; get data
    MOVWF POSTINC0
    DECFSZ COUNTER
    BRA READ_BYTE
    EndReadFlash
    RETURN
    ;Write a block of data from BUFF_ADDR into CODE_ADDR length BUFF_LEN
    FlashWrite:
    MOVFF BUFFER_LEN, COUNTER_HI ; number of bytes to write
    RRNCF COUNTER_HI,F
    RRNCF COUNTER_HI,F
    RRNCF COUNTER_HI,F ;Divide by 8
    MOVF COUNTER_HI, W
    ANDLW b'00011111' ;Mask off rotated bits
    MOVWF COUNTER_HI
    MOVFF BUFFER_ADDR_HIGH, FSR0H ; point to buffer
    PROGRAM_LOOP
    MOVLW 8 ; number of bytes in holding register
    MOVWF COUNTER
    WRITE_WORD_TO_HREGS
    MOVF POSTINC0, W ; get low byte of buffer data
    MOVWF TABLAT ; present data to table latch
    TBLWT+* ; write data, perform a short write
    ; to internal TBLWT holding register.
    DECFSZ COUNTER ; loop until buffers are full
    BRA WRITE_WORD_TO_HREGS
    PROGRAM_MEMORY
    BSF EECON1,EEPGD ; point to FLASH program memory
    BCF EECON1,CFGS ; access FLASH program memory
    BSF EECON1,WREN ; enable write to memory
    BCF INTCON,GIE ; disable interrupts
    MOVLW 55h
    MOVWF EECON2 ; write 55h
    MOVLW 0AAh
    MOVWF EECON2 ; write AAh
    BSF EECON1,WR ; start program (CPU stall)
    BSF INTCON,GIE ; re-enable interrupts
    DECFSZ COUNTER_HI ; loop until done
    BRA PROGRAM_LOOP
    BCF EECON1,WREN ; disable write to memory
    RETURN
    ERASE_BLOCK
    MOVFF CODE_ADDR_UPPER, TBLPTRU ; load TBLPTR with base address of memory
    block
    BSF EECON1,FREE ; enable Row Erase operation
    MOVLW 55h
    MOVLW 0AAh
    BSF EECON1,WR ; start erase (CPU stall)
    TBLRD*- ; dummy read decrement
    return
