PIC16F877A : How to config PORTA as analog i/p and PORTE as digital o/p
Discussion in 'Microcontrollers, Programming and IoT' started by grom, Dec 7, 2010.
  1. grom
    grom
    23
    Dec 5, 2010
    I have this PIC16F877A development board with a 16x2 alphanumeric LCD display where the tracks connect the data pins of the LCD to PORT D and the control pins: RS, R/W, and E to PORT E.
    I use C language to program(MikroC)
    my purpose is to take an analog i/p from RA0 and give the o/p to the LCD (through ports B and E ).
    for initialising ports, i do this:
    void init_ports()
    ADCON0.ADCS1=1;
    ADCON0.ADCS0=1;
    ADCON0.CHS2=0;
    ADCON0.CHS1=0;
    ADCON0.CHS0=0;
    ADCON0.f2=0; //for ADGO
    ADCON0.ADON=0;
    ADCON1.ADFM=0;
    ADCON1.PCFG3=0;
    ADCON1.PCFG2=0;
    ADCON1.PCFG1=1;
    ADCON1.PCFG0=0;
    and for configuring the output to the LCD, i have to use the Lcd_custom_config(&dataport,....,&controlport,...)
    so i use this:
    main()
    init_ports();
    TRISE=0;
    TRISB=0 ;
    LCD_Custom_Config(&PORTB,3,2,1,0,&PORTE,2,1,0);
    but when i implement it, it doesn work at all... and when i try it in Proteus ISIS, it doesn work and i get a thousand warnings shown in the attached picture.
    i've tried a lot but then in the end i jus gave up and used:
    LCD_init(&PORTB)
    and used three jumper wires to connect the control pins now configured to be in port B to the three pins in port E
    can some one please help me?
    sad[:'(]:confused:
      File size:
      44.1 KB
      318
  2. 1mshop
    1mshop
    Dec 23, 2010
    Hi Grom,
    You mentioned that your LCD data pins are connected to Port D while you are sending the LCD data to Port B, this will not work for sure.
    Try change your code so the LCD data is send to Port D.
    Hope this helps.
    Thanks.
    Regards,
    1Mshop Team
    www.1mshop.com
