A
Ankur
Hi all,
Someone please help me out..
Please see the program below which is working the way i don't want it
to.
I've interfaced 5leds to PORTA( i'v used a pull-up in PA4 pin) and am
trying to work out a binary counting on the 5leds.The trigger to count
is being given by RB<7:4> pin state change. So, whenever i change the
state of any of RB<7:4>, i should see a count UP on the leds(say it
was 00001 earlier, i should see 00010 on changing the state of
RB<7:4>pins)
But the problem i am facing is that the program comes back into the
Main Loop inspite of a "Wait Loop" provided. I don't know but after
the first interrupt, the program runs back into Main.
b'bye and thnx
******************************************PROGRAM*******************************
#include "p16f84a.inc"
count equ 0Ch ;First counter for our
delay loops
bank0 macro
bcf STATUS,RP0
endm
bank1 macro
bsf STATUS,RP0
endm
org 0x00
goto Main
org 0x04
goto ISR
org 0x10
Main
bank1
clrf TRISA ; portA configured as OUTPUT
movwf 0xff
movwf TRISB; portB configured as INPUT
bank0
movlw 0xff
movwf PORTA
movlw 0x04
movwf count ; count=4
bank1
movlw b'00000111'
movwf OPTION_REG ; for timer prescalar 1:256
; ;configure INTCON
bsf INTCON,RBIE ;RB port change Interrupt Enable bit
bsf INTCON,GIE ; Enable interrupts!!
loop
nop
goto loop ; wait state
ISR
bank0
;we inc. 'count' every time ISR is executed & send it on PORTA to
verify.
incf count,f ;when i used "incf PORTA"
movf count,w ;instead of these 3
commands*****************************************
movwf PORTA ;it did not
work.****************************************************
bcf INTCON,RBIF ; IMPORTANT - clear back the interrupt flag
BSF INTCON,GIE ; IMPORTANT! - re-enable the interrupts
return
goto loop
end
to.
RB<7:4>pins)
b'bye and thnx
delay loops
bank0 macro
bcf STATUS,RP0
endm
bank1 macro
bsf STATUS,RP0
endm
org 0x00
goto Main
org 0x04
goto ISR
org 0x10
Main
bank1
movwf 0xff
bank0
movlw 0xff
movwf PORTA
movlw 0x04
bank1
movlw b'00000111'
; ;configure INTCON
loop
nop
ISR
bank0
verify.
return
goto loop
end
