R
Richard Swinfen
Need some advice on powering a bank of fluorescent lights. My
controller uses a PIC 16F876 to a 2803 Darlington array to power 10A
240V relays one of which powers the 240v AC light bank. There are
about 9 lights in the bank (my garage), ranging from 40W to 70W, each
with their own starter, amounting to about 450W operating power.
Other relays power other light banks lesser in number and operating
power, with no problem.
The problem symptom is a resetting PIC when the relay is fired. The
same happens if the lights are powered by the original light switch.
The problem cause I believe is inductive spikes during the lights
power-up cycle. I have scanned the groups and can't see this specific
problem being discussed. What is discussed has led me to try
varistors across the load and across the relay contacts both at the
relay. I think, by doing that, I am preventing the spikes from being
inducted through the relay into the DC power lines, spiking the PIC.
However, I have read that this might not prove a good solution if
spiking is regular. In any case, it doesn't work, and in fact seems
to cause the problem to occur more consistently now.
I haven't yet attempted an RC snubber - not totally convinced on what
I would be achieving with that and would prefer some specific advice
on the problem first.
If you can help, I would be most grateful.
Regards,
Richard.
Regards,
Richard.
