PIC pwm calculation
Discussion in 'Microcontrollers, Programming and IoT' started by ami85t, Mar 30, 2014.
  1. ami85t
    ami85t
    71
    Feb 19, 2014
    I’m trying to figure out how to calculate the PWM duty cycle and frequency using a PIC16f877.
    The equation for the d.c. is:
    PWM duty cycle = (CCPR1L:CCP1CON<5:4>) • TOSC • (TMR2 prescale value)
    I want to create a 50% duty cycle wave. I have a crystal of 8 and 16 MHz.
    The minimum value which is available for the (CCPR1L:CCP1CON<5:4>) which I got to is 17D7840 (HEX) which of course is much more than 3 HEX digits.
    What am I missing here? Is my equation supposed to look like this:
    50= X * (1/8M max) * 16max ?
    Thanks, Amitai
  2. jpanhalt
    jpanhalt
    426
    4
    Nov 12, 2013
    The equations work fine. The point you are missing is that the duty cycle is defined by Microchip in units of time:
    If you want duty cycle as a fraction, then you need to divide the duty cycle time by the period. For duty cycle as a percentage, convert that fraction in the usual way.
    John
  3. ami85t
    ami85t
    71
    Feb 19, 2014
    Thanks, I exactly figured it out.
    I have changed the code a little and read a few things which I tried out but
    I see that the capture module doesn't work for some reason.
    I inserted the led section in the program for verifying that the loop in the code works for the different sections.
    The led does turn on and the first transmitting part does it's job. but the led doesn't flicker - what means that
    there's something wrong at the loop for checking the PIR2, CCP2IF.
    Do the sections of the code for the PWM and capture seem correct? do I need to power on the timer1 only before the
    capturing process and use the flags the way I did?
    Thanks, Amitai
    Code:
    LIST	P=PIC16F877
    include	<P16f877.inc>
    org		0x00
    	__CONFIG _LVP_OFF &_WDT_OFF &_PWRTE_OFF &_CP_OFF & _HS_OSC
    	reset:
    	nop
    	goto	start
    	org		0x20
    start:
    ; configuration
    ; used_ registers:
    	MUX_sel			EQU H'0021'  		; for not transmitting '000000000'
    	del1			EQU H'0030'  		; for delay
    	del2			EQU H'0031'  		; for delay
    	tro_transmit	EQU H'0050'  		; Frequency data register
    	chk_zero		EQU H'0055'  		; for not transmitting '000000000'
    	demo_send	 	EQU H'0056'  		; FF sent in beginning
    	led1			EQU H'0070'  		; for led delay
    	banksel		ADCON1
    	movlw		0x07				; pin RA5 is configured as a digital I/O
    	movwf		ADCON1
    ;UART/*/*/
    	banksel  	TXSTA
    	movlw    	0x24        		 ; master, transmit EN, sync mode, Transmit Shift Register empty
    	m[CODE]
    ovwf TXSTA ; Baud Rate = Fosc/(4(SPBRG+1)) , BRGH (baud rate) ignored in sync
    banksel TRISC
    bsf TRISC, 6
    bsf TRISC, 7
    banksel SPBRG
    movlw 0x10 ; = d"16" which corresponds to 15Kbps with 8MHz clock
    movwf SPBRG
    banksel RCSTA
    movlw 0x80 ; enable UART
    movwf RCSTA
    ;PWM, timer2/*/*/
    banksel TRISC
    bcf TRISC, 2 ; make the CCP1 pin an output.
    banksel T2CON
    movlw 0x04
    movwf T2CON ; no post/Prescaler (1:1) , TMR2 ON
    banksel PR2 ; output frequency = 15000hz =
    movlw 0x84
    movwf PR2 ; 1 / [(PR2) + 1] • 4 • TOSC •(TMR2 prescale value)
    banksel CCPR1L ;duty cycle =(CCPR1L:CCP1CON<5:4>) • TOSC • (TMR2 prescale value)
    movlw 0b01000010
    movwf CCPR1L
    banksel CCP1CON
    movlw 0b00111100
    movwf CCP1CON
    ;capture, timer1 /*/*/
    banksel TRISC
    bcf TRISC, 1 ; make the CCP2 pin an output.
    banksel T1CON
    movlw 0x09 ; Timer1 Input Clock Prescale 1:1, en TMR1
    movwf T1CON ; , int clk (fosc/4) , oscillator en
    banksel CCP2CON
    movlw 0x07
    movwf CCP2CON ; Capture mode, every 16th rising edge
    banksel PIE2
    bcf PIE2, CCP2IE ; avoid false interrupts
    ;MUX select
    banksel TRISD
    bcf TRISD, 0
    bcf TRISD, 1
    bcf TRISD, 2
    ;LED general delay
    bcf TRISD, 4
    bcf TRISD, 5
    banksel PORTD
    bcf PORTD, 4
    bcf PORTD, 5
    ; end configuration --------------------------------------
    ;************ MAIN PROGRAM ***************
    main:
    ;MUX init
    movlw 0x07
    movwf MUX_sel
    ;transmit check /*/*/*/*
    CALL DELAY
    movlw 0xFF
    movwf demo_send
    movf demo_send, w
    CALL transmitting_data
    main_loop:
    Led_flicker:
    movlw 0xFF
    movwf led1
    t2:
    CALL DELAY
    CALL DELAY
    CALL DELAY
    CALL DELAY
    decfsz led1
    goto t2
    bcf PORTD,5
    bsf PORTD,4
    banksel led1
    movlw 0xFF
    movwf led1
    t1:
    CALL DELAY
    CALL DELAY
    CALL DELAY
    CALL DELAY
    decfsz led1
    goto t1
    bcf PORTD,4
    bsf PORTD,5
    ;---end Led flicker
    ;capture frequency/*/*
    banksel TMR1H
    clrf TMR1H
    clrf TMR1L
    check_capture:
    banksel PIR2
    btfss PIR2, CCP2IF ; 1 = A TMR1 register capture occurred (must be cleared in software)
    goto check_capture
    ;transmitting data
    banksel CCPR2H ; transmit MSB
    movf CCPR2H, w
    banksel tro_transmit
    movwf tro_transmit
    banksel CCPR2L ; transmit LSB
    movf CCPR2L, w
    movwf tro_transmit
    ;MUX select/*/*/
    movf MUX_sel,w
    banksel PORTD
    movwf PORTD
    decfsz MUX_sel
    goto main_loop
    movlw 0x07
    movwf MUX_sel
    goto main_loop
    ;******** END MAIN LOOP ********************
    transmitting_data:
    banksel TXREG
    movwf TXREG ; writing to TXREG clears TXIF
    trans_wait2:
    btfss PIR1, TXIF ; wait for the frame to be transmitted
    goto trans_wait2
    CALL DELAY
    return
    DELAY:
    movlw 0xFF
    movwf del1
    movlw 0xFF
    movwf del2
    loopa:
    decfsz del1, f
    goto loopa
    loopb:
    decfsz del2, f
    goto loopb
    return
    end
    [/CODE]
