PIC programmer
Discussion in 'Microcontrollers, Programming and IoT' started by pebe, Mar 11, 2016.
  1. pebe
    pebe
    83
    11
    Sep 3, 2013
    What programmer would you recommend for a PIC 12F1571?
    I will probably use this chip only once, so I don't need one with all the bells and whistles.
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    hevans1944 likes this.
  3. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    You can do it properly, or 'make-due' ...
    Usually you can make a programmer with a few spare parts and a serial port on the PC, but the PIC requires a higher voltage than the typical 3.3V or 5V you will be working with.
    You will save yourself a lot of time and parts to simply buy a pickit programmer... or if you are flexible on the MCU you need, buy an arduino. They are cheaper than an AVR or PIC when you factor in 'single project' and 'programmer'.
    If you will be programming more than one MCU, splurge on an AVR or PIC programmer for your chip.
  4. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    What do you mean PIC requires higher voltage?
    cheers
    Adam
  5. Minder
    Minder
    3,122
    673
    Apr 24, 2015
    Check to see if Pic-kit 2 will program a 12F1571 there is a stand alone program Picit2 V2.61 that has a digital analyzer etc in it which can be handy.
    M.
  6. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    PIC requires a 12V source to enable the flashing process.
    Vpp, provided on pin 1 of the PicKit2 and 3
  7. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Not if you use LVP.
    Adam
    Gryd3 likes this.
  8. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    It wont, I checked first to see if it does.
    Adam
  9. pebe
    pebe
    83
    11
    Sep 3, 2013
    Thanks for your replies and I'll use a PIC-KIT-3 as Adam suggested.
    In the past I have used 12F629/675 and 16F676 and programmed them with a K150 based programmer. Bit it won't work with the newer PICs that have 4digit numbers.
    Arouse1973 likes this.
