PIC Program Help Wanted - To control an automotive shift light
Discussion in 'Hobby Electronics' started by Jamie, Aug 13, 2003.
  1. Jamie
    Jamie Guest
    Is there anyone here that has experience with PIC's and is willing to create
    a program which will control an output if a certain frequency is exceeded on
    an input of a PIC? (i know it can be done with an LM 2917, but really want
    to do it digitally, and i've never played with a PIC before)
    If you have any information, or are willing to help, please email me at:
    jamie_s_22 at hotmail dot com
  2. happyhobit
    happyhobit Guest
    Hi Jamie,
    Well I’m into AVR microcontrollers and not PIC’s but the ideas are the same.
    If the input signal is analog (Sine wave) using a microcontroller with an
    analog input, you could measure the time between the peak of one cycle and
    the next. If the input is digital (on/off) you don’t need the analog
    inputs.
    Frequency = 1 / time, 1 ms = 1000 hertz, 100micro seconds = 10,000 hz., etc…
    You’ll have to condition the input signal so the voltage is within an
    acceptable range. (Resisters in a voltage divider)
    Jay
  3. Rob Judd
    Rob Judd Guest
    You're a bit out of date there Mike. These days you'd use a 16F84 or
    16F628. They're cheap as anything and less pins to worry about.
    Rob
