Hello,
I am using a programmer to burn my hex file into pic18F4520.
http://www.nskelectronics.com/pickit2.html
now the problem that i am facing is as follows:
when i use a DIP package and burn the program into IC it works fine.
however i have designed a circuit using QFP80P1200X1200X120-44 package, it is here that i am facing a problem.
when I write a following code:
it is burning into the controller and working ok,
however when I write the following code:
here i am facing a problem the error that i get is as follows:
programming failed at program memory address 0x00000.
however both the program get dumped in pic18f4520 DIP packages.
I have no clue what exactly is the problem now,.
please help..
-Sid
Code:
#include <18F4520.h>
#device ICD=TRUE ADC=10
#fuses HS,NOLVP,NOWDT
#use delay (clock=16Mhz)
void main()
while(1)
output_high(Pin_c6);
delay_ms(500);
output_low(Pin_c6);
delay_ms(500);
Code:
#include <flex_lcd.c>
void main()
lcd_init();
while(1)
printf(lcd_putc,"\f hello\nworld");
delay_ms(1000);
delay_ms(500);
output_low(Pin_c6);
delay_ms(500);
please help..
-Sid
