PIC microcontrollers
Discussion in 'Electronic Design' started by Jeff Findley, Aug 1, 2006.
  1. Jeff Findley
    Jeff Findley Guest
    I'm looking to get started using PIC microcontrollers and was looking for a
    good forum for discussing the basics. Questions like, given that I want to
    run an PIC18 microcontroller at 40 MHz, for the external clock, would it be
    better to use a ceramic resonator or a crystal (presumably with the required
    parallel resistor and two capacitors).
    So, is this the right newsgroup? Are there better online forums for this
    topic?
    Jeff
  2. Try
    http://forum.microchip.com/
  3. Most of the PIC 18 chips, _will not_ run at 40MHz, with an external
    crystal or resonator (they will with a complete external oscillator). The
    maximum internal oscillator frequency is usually 25Mhz, but the chips have
    a *4 PLL, and you run the oscillator at 10Mhz, with the PLL enabled,to
    have the chip run at 40MHz.
    A crystal will be more accurate in general, the resonator will be cheaper.
    Microchip have a fairly good forum.
    Particular software development tools/kits, will have their own sites.
    Best Wishes
  4. Jeff,
    A good place to start is:
    http://www.voti.nl/swp/n_index.html
    Which also provide several usefull links including the ones below.
    Another wellknown site:
    http://www.piclist.com/techref/piclist/index.htm
    Official info on:
    http://www.microchip.com
    Which includes a link to the forum mentioned by Richard Henry.
    petrus bitbyter
