PIC microcontroller
Discussion in 'Microcontrollers, Programming and IoT' started by bigone5500, Sep 27, 2014.
  1. bigone5500
    bigone5500
    712
    121
    Apr 9, 2014
    I have salvaged a circuit board and on it was a PIC16C63A-04/SP. I have only found datasheets on google and want to know if this can be used like an Atmega328.
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    What do you mean can be used like the Atmega328? Are you thinking of using the device you have? I think your going to have problems there. It's one time programmable. I think the only time you can reliably re-program it is if you knew where the last address of program memory was and start your code from there but again your gong to struggle if they have used all the code space.
    Adam
  3. bigone5500
    bigone5500
    712
    121
    Apr 9, 2014
    Thanks. I didn't know it was a one use thing. I was hoping I could use it in a breadboard. But I have some Atmega328 chips coming.
  4. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    That's what the C is. The re-programmable versions have an F in the part number like PIC16LF84A. These parts are flash devices and can be re-programmed.
    Adam
    KrisBlueNZ and Supercap2F like this.
  5. bigone5500
    bigone5500
    712
    121
    Apr 9, 2014
    Thanks Adam. I read through the PDF but didn't understand it very well...
    BTW: This chip came from a control board used in a dust collector. The board controlled whether or not the filters were cleaning due to differences in the clean side and dirty side. It is called a DeltaP controller.
  6. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Ok no probs
    Adam
