E
[email protected]
I am playing with PIC microcontroller 16F628.
I am seeing high frequency ringing on my power supply with nothing else
hooked up, except the voltage regulator and the PIC. The noise goes
away when I pull the PIC so its not the power supply. (Lab supply -->
7805 regulator)
The waveform is:
around 15 mHz
15mV peak to peak
I have input capacitance on my regulator 100uF and output 4.7uF and a
bypass cap next to Vcc at the PIC of .1uF The circuit is wire wrapped,
and am taking everything back to a common ground pin. The waveform has
been observed on two different scopes. Also, I pulled out one of my
older projects, using a PIC16F628 and the waveform is visable on the
rails there too.
Any idea where this waveform is coming from and better yet how do I
flat line it? I realize 15mV is not that large but I am trying to
amplify a small DC voltage with an op-amp, and I also have a 12 bit ADC
that will use the positive side of this rail as voltage reference.
The waveform looks like a decaying Sine wave, amplitude large then
slowly decaying and then amplitude spikes large and then slowly decays
over and over at about 15mHz.
I may be picking nits, but would like to get rid of it, I guess I could
build another separate rail for my Vref and Op Amp but it seems
wasteful.
Thanks for any help
ED
7805 regulator)
The waveform is:
around 15 mHz
15mV peak to peak
rails there too.
wasteful.
Thanks for any help
ED
