PIC I/O lines when configured as input or output
Rajinder
Jan 30, 2016
568
Jan 30, 2016
568
I am trying to understand what happens 'internally' (on a hardware level) to a PIC I/O line when it is configured as an input / output or high impedance.
I know that there are N and P channel FETs which are set accordingly when the port is set i.e. to sink or source current.
I need a better understanding. Can anyone help?
Thanks in advance
Harald Kapp
13,700
13,700
Have a look at figure 4-10 in this datasheet. Do not get confused by the different options shown there. The basic prionciple is the same:
The port is always an input through the Schmitt-Trigger gate at the bottom of the diagram. The bus driver to the internal dat bus is enabled by the signal RD_PORTC when data is read from the pin.
When configured as output, the ouput driver is enabvled by the control signal from the lower flip-flop that stores the enable signal for that port pin using the WR_TRISC control signal. How this tri-state bufffer works is explained e.g. here.
Rajinder
Jan 30, 2016
568
Jan 30, 2016
568
Thanks for your assistance. I will have a good look at the articles. Much appreciated.
