Pic CRC
Discussion in '8bit Microcontrollers' started by [email protected], Mar 4, 2004.
  1. Guest
    Has anyone got any info/routines for CRC/Hamming/Golay etc for pic
    micros... If not, I code my own.
    Thanks.
    SeG.
  2. Dan Henry
    Dan Henry Guest
    Yes, and I sent a ZIP file of it all, but the e-mail kept bouncing.
    I give up!
  3. Rich Webb
    Rich Webb Guest
    Google for "A painless guide to CRC error detection algorithms" by Ross
    Williams. After reading it, you should find it fairly straightforward to
    put together a table-driven implementation.
  4. Guest
    Sorry Dan... I Hadn't set my news reader up correctly. The addr on this
    post should be correct. I would really appreciate those zips.
    Thanks.
    SeG.
  5. Dan Henry
    Dan Henry Guest
    I'll not be attempting anymore e-mails until my patience is restored.
    To show my earnest intentions however, I'll simply point you to a
    document of mine where you can extract a standard CRC implementation
    that is a particularly good tradeoff between code size and speed when
    realized on a PIC (using the HI-TECH PICC compiler, at least). Please
    refer to Fcs16_b() on PDF page 11 (document page 8) of:
    http://dhenry.home.sprynet.com/hdlcbcc.pdf
    Since you are only interested in the "CRC/Hamming/Golay etc", you'll
    have to ignore the rest of the protocol drivel.
  6. ego
    ego Guest
