Frank3point14
- Sep 6, 2013
- 10
- Joined
- Sep 6, 2013
- Messages
- 10
Hello
Check out this code and tell me what i am doing wrong>..
I am using PIC18F4331
I am trying to configure the external interrupts int1 and int2
Code:
//LCD connections
sbit LCD_RS at RD5_bit;
sbit LCD_EN at RD4_bit;
sbit LCD_D7 at RB5_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D5 at RB0_bit;
sbit LCD_D4 at RD6_bit;
sbit LCD_RS_Direction at TRISD5_bit;
sbit LCD_EN_Direction at TRISD4_bit;
sbit LCD_D7_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D5_Direction at TRISB0_bit;
sbit LCD_D4_Direction at TRISD6_bit;
//functions
void timer1_init(); // initialize TIMER1
void inbuiltF_init(); // initialize inbuilt functions
void interrupts_init(); // initialize interrupts
void interrupt();
void display_lcd();
// global variables
int calpid = 0; // pid loop run command
int ledon = 0;
int x = 0;
void interrupt(){
if(PIR1.TMR1IF==1){
calpid = 1; // run PID loop
TMR1L = 181; //// preload timer1
TMR1H = 179; ////
PIR1.TMR1IF = 0;
if(INTCON.INT0IF==1){
ledon = 1;
INTCON.INT0IF = 0;
if(INTCON3.INT1IF==1){
ledon = 1;
INTCON3.INT1IF==0;
if(INTCON3.INT2IF==1){
ledon = 1;
INTCON3.INT2IF==0;
void main(){
TRISC.F7 = 0;
PORTC.F7 = 0;
inbuiltF_init();
interrupts_init();
timer1_init();
while(1) {
while(ledon==1){
Lcd_Out(1,1,"led on");
Delay_ms(100);
Lcd_Out(1,1," ");
ledon = 0;
while(calpid==1){
x = x + 1;
if(x<128){
PORTC.F7 = 1;
else if(x<512){
PORTC.F7 = 0;
else if(x==512){
x = 0;
calpid = 0;
void timer1_init(){ // initialized to give 256Hz interrupt for PID loop execution
TMR1L = 181; // preload timer1
TMR1H = 179;
T1CON.RD16 = 1; // enable register read/write of TIMER1 in two 16-bit operations[7](1)
T1CON.T1RUN = 0; // system clock is derived from another source [6](0)
T1CON.T1CKPS1 = 0; // ##increments with 1:2 prescale value [5](0)
T1CON.T1CKPS0 = 1; // ## [4](1)
T1CON.T1OSCEN = 0; // TIMER1 oscillator is shut-off [3](0)
T1CON.TMR1CS = 0; // TIMER1 uses internal clock (FOSC/4) [1](0)
T1CON.TMR1ON = 1; // enable TIMER1 [0](1)
void inbuiltF_init(){
Lcd_Init();
Lcd_Cmd(_LCD_CLEAR);
Lcd_Cmd(_LCD_CURSOR_OFF);
void interrupts_init(){
RCON.IPEN = 0; // disable priority levels on interrupts (0)
INTCON.GIE = 1; // global interrupts enabled (1)
INTCON.PEIE = 1; // enable all unmasked peripheral interrupts (1)
PIE1.TMR1IE = 1; // TIMER1 overflow interrupt enabled (1)
IPR1.TMR1IP = 0; // TIMER1 overflow interrupt set to low priority (0)
PIR1.TMR1IF = 0; // clear TIMER1 overflow interrupt flag (0)
INTCON.INT0IE = 1; // RC3 external interrupt enable (1)
INTCON2.INTEDG0 = 1; // external interrupt0 RC3 on rising edge (1)
INTCON.INT0IF = 0; // clear RC3 INT0 interrupt flag
INTCON3.INT1IP = 0; // INT1 external interrupt priority - low (0)
INTCON2.INTEDG1 = 1; // external interrupt1 RC4 on rising edge
INTCON3.INT1IF = 0; // clear RC4 INT1 interrupt flag
INTCON3.INT1IE = 1; // RC4 external interrupt enable
INTCON3.INT2IP = 0; // INT2 external interrupt priority - low (0)
INTCON2.INTEDG2 = 1; // external interrupt2 RC5 on rising edge
INTCON3.INT2IF = 0; // clear RC5 INT2 interrupt flag
INTCON3.INT2IE = 1; // RC5 external interrupt enable
