PIC 16F877 can't read eeprom
Discussion in '8bit Microcontrollers' started by Pete Shew, Oct 21, 2004.
  1. Pete Shew
    Pete Shew Guest
    I am developing using an 16F877 with the EPE IceBreaker system (an
    ICD) and I can't read the EEPROM. I can't even modify registers 18C
    (EEADDR) and 18D (EEDATA) from program code, although I can modify
    18A. I CAN modify 18C and 18D from the IceBreaker GUI, and display the
    EEPROM contents.
    Running the program with the debugger diabled shows the same symptoms
    that I see in the debugger, from which I infer that the read is
    failing then too.
    Is this a feature of the IceBreaker system (maybe to prevent reading
    of program flash and hacking their code)? Anyone had this problem
    before?
    Pete
