N
Niels Damsgaard-Sørensen
Hi group. Before i'm pulling out all my hair (still a bit left), i better
ask for some advice here:
I'm working on two different boards, both with a'n Pic 16F819 SOIC. I have
made a lot of these boards earlier, programming onboard with a Picstart.
This time i made up 20 of each and started programming the same o'l Hex to
the boards, but nothing semed to work. Took the whole lot with me home for
the weekend and tried my own ICD2. Same result :-( Problem seemes to be,
that all chips are write/code protected. Im sure i made the fusesettings in
MPLAB right, no fusesettings in software. In Microchips errata it says these
chips can be difficult, in the Picstart helpfile in MPLAB it says : add a 1k
pulldown to MCLR. Could failing to do so cause the chips to be
code-protected ? And should i not be able to remove ALL fuses with a general
erase?
Any ideas ?
Niels
erase?
Any ideas ?
Niels
