pic 12f675 programming
Discussion in 'Microcontrollers, Programming and IoT' started by gurjant.sandhu33, Feb 23, 2014.
  1. gurjant.sandhu33
    gurjant.sandhu33
    51
    Dec 10, 2013
    i have a pic 12f675 micro controller,
    i want to know that can i programme it through usb by using bootloader (through serial to usb converter) as i dont have a serial port.
    also i have a pic 16f870 which i use to programme by first loading the boot.hex file through serial and then do normal programming using serial to usb converter.(can something like this be done to pic 12f675)
  2. hexreader
    hexreader
    127
    42
    Apr 21, 2011
    PIC12F675 cannot be programmed using USB or serial.
    You will need PICkit3, PICkit2 or similar hardware programmer.
    To reduce the chances of problems, I would recommend buying a genuine Microchip (or mikroElektronika) programmer, not a clone.
