S
Spehro Pefhany
John said:On Mon, 04 May 2009 09:32:54 -0700, Joerg
John Larkin wrote:
On Sun, 03 May 2009 15:22:14 -0400, Spehro Pefhany
On Sun, 03 May 2009 11:21:42 -0700, the renowned John Larkin
On Sun, 03 May 2009 09:53:37 -0700, Joerg
John Larkin wrote:
On Sat, 02 May 2009 21:29:47 GMT, James Arthur
John Larkin wrote:
On Sat, 02 May 2009 13:14:40 -0700, Joerg
John Larkin wrote:
This weekend I'm going to buy a tin of Danish sugar cookies, eat all
the cookies, and build a pA range diode-curve measuring setup into it.
I have a bunch of LMC6001s (Ib is 10 fA typ) to use. The datasheet
hints somewhere in one of the app circuits that Cin is big. But it's
not specified anywhere.
It's "Danish Butter cookies"
Make sure to _throughly_ clean it before you build anything into it,
until wiping shows no grease residue. Else you might experience an
impressive meeting of ants in there. BTDT.
The rule seems to be that if Cin is large, don't mention it on the
datasheet.
Cin is probably largish and usually not used directly:
http://www.postech.ac.kr/ee/paust/p...a Beam-Profile Monitor for Cyclotron MC50.pdf
Interesting; that's vaguely like what I'm tying to do. But I can't
find a datasheet on the JU421, even on the Vishay site, so I assume
it's another FormerFet.
www.vishay.com/docs/70248/70248.pdf
Cheers,
James Arthur
Cool. Vishay didn't recognize "JU421".
Nice part for leakage, but with En=30 nv/rthz and Gm=200 uS, it's sort
of the Marching Band of Noise. This guy adds a second one in
differential mode to add bonus noise and lower the gain to boot.
Well, good luck finding one
If you do it'll probably have "DoD pricing".
Why do these scientific types so love differential jfet front-ends?
In electronics they tend to hang on to stuff much longer than we do.
I hadn't paid much attention to discrete jfets in, well, some decades.
They have low transconductance, high capacitances, miserable matching,
and astounding datasheet parameter spreads, like 10:1 Idss limits.
But for really low noise (like, under 1 nV/rthz) amplification of
high-impedance signals, nothing can touch them. The best fet opamps
are, like, 5x as noisy as the best jfet.
True.
Pity that most people, at
least the scientists, trend to use them wrong.
John
What wrongness have you seen? The commercial stuff for research
applications looks pretty decent to me.
I see mostly botched circuit protection. Last one: A freaking expensive
laser diode driver with TEC in there was running. Janitor plugged vacuum
into same circuit, turned it on ... tzzzt ... phut ... *POP*
That isn't supposed to happen.
I've seen a lot of diffamps where it wasn't necessary, really rotten
second stages (the fets have low gain, so 2nd stage noise matters) and
circuits where the Johnson noise of gate bias resistors (and
occasionally drain load resistors!) overwhelmed the fet's noise. One
paper got around that by testing the amp with a grounded input!
Could it be that there just aren't a lot of good disctete circuit
designers around? I would hate to think that.
That is most definitely the case :-(
OTOH, this puts bread on the table around here ...
Most people can be adequate carpenters or painters or cooks. Not many
people, even with engineering or physics degrees, can be decent
circuit designers.
That's sort of weird. I guess circuit design is really more art and
instinct than science.
It is, but include cooks as well. Had salmon at Sudwerks yesterday,
exquisite. But I had a very similar salmon dish in other restaurants and
it was bland. Good cooks must know how much a tad, a dash and a smidgen
is yet very few really know. Just like there are engineers who slap the
biggest hinking inductor they can fit onto an EMC problem, and later
many units go bzzzap ... *POOF* upon disconnecting power.
Did you learn all those sound effects the hard way ?
...Jim Thompson
Are you accusing Joerg of being a *POOF*ter?
