Hello Jack,
I have a circuit and PDF PC board layout that could be modified into
what you need, especially triggering off a low level lamp output. This
will be using a photo-transistor which is more sensitive. Also using a
low powered TLC555 gives you a CMOS Schmidt Trigger.
http://www.oldtemecula.com/theremin/rs-opticaltheremin/rs-opticaltheremin.htm
If you leave everything as I designed, it would pulse/buzz a small
speaker every flash of the dim lamp.
Modifications for what you indicated:
Leave off C1 so it does not output a tone (oscillate), then adjust the
value lower of R2 a 1Meg resistor to give you the trip point you need.
Remove and "jump wire" C2 for a DC rail to rail voltage swing on the
output. Leave Pin 7 of the TLC555 disconnected or cut the copper foil.
Better yet use a IC socket and leave this IC pin folded upward.
Pin 7 is just above the "1" of the U1 label on the IC graphic.
Pin 1 has a black dot above it and the pins number counter clockwise.
I would like to find a schematic for a photocell feeding a schmidt
trigger (CMOS). This will input the light from a not-very-bright panel
lamp. It is also very slow speed (once-a-half-second).
Any URL available?
Thanks for any help.
Christopher
Temecula CA.USA
