In the past when I've needed a one-off PCB I've used the process where you print with a laser printer on a blue film and then use an iron to transfer the print to the copper coated board. I've learned that if i print about 4 copies of my circuit then one of the transfers might be usable after dissolving away the copper. I need to find a better way.
I've seen people that suggest using a laminator to transfer the mask, and I guess I could go that direction. What I'm wondering is, is that any better than using a photo etch process? I've never used a photo etching system, so I'm wondering, is it any more reliable than the iron-on method?
If anyone has any thoughts to share regarding the different methods, I'd appreciate the info.
Thanks.
Thanks.
