Phoenix Contact 24vdc 40A power supply repair
Discussion in 'Troubleshooting and Repair' started by bigone5500, Jan 23, 2016.
  1. bigone5500
    bigone5500
    712
    121
    Apr 9, 2014
    I got a power supply from work out of the recycle bin. This is the one I have. I connected 110v to it and there is no voltage on the output side. I will take it apart and do some testing to see what I can find. I have taken it apart once but just to see if the fuse was good and it was. I think this unit retails for around $900 so I think it would be worthwhile to repair if possible. I did a quick look over and found that the small filter caps on the output are swelled. I am wondering if the transformer on that side is bad. The caps are 35v 1200uf and there are 4 of them. The large caps look to be ok. They are 420v 390uf.
    I am starting this thread for reference. I also would like input for what to look for and tips on troubleshooting these things. I do know that when working with this type of equipment that safety is paramount. Large caps can hold charge for a long time and are lethal.
    [​IMG]
  2. davenn
    davenn Moderator
    13,866
    1,958
    highly unlikely that the transformer would have failed
    caps and semiconductors would be the first choices
  3. Minder
    Minder
    3,102
    664
    Apr 24, 2015
    That is a SMPS type, so I would check the large semi conductors for a start, replace any bad looking caps.
    The transformer is a switch mode type and a shorted turn is a possibility.
    M.
  4. bigone5500
    bigone5500
    712
    121
    Apr 9, 2014
    Took it apart and found another component that I think may be bad too. There is some smoke around it and the solder joint looks iffy too.
  5. davenn
    davenn Moderator
    13,866
    1,958
    yeah seriously dry jointed and have been arcing
  6. bigone5500
    bigone5500
    712
    121
    Apr 9, 2014
