Phillips TV - screen scratches
Discussion in 'Electronic Repair' started by [email protected], Jun 25, 2007.
  1. Guest
    Got a large widescreen Phillips CRT type TV that has got some small
    scratches on the screen...
    It looks as if the actual TV screen has got a very soft outer covering
    layer or something. Consequently, it looks its been marked every so
    slightly in loads of places...
    Any idea how I could get these scratches out or anything ?
  2. JANA
    JANA Guest
    You cannot take out the scratches without damaging the anti-glare surface.
    There are a number of methods used for fusing this coating to the front
    glass. If you try polishing the screen, you will remove the coating, and
    thus damage the rest of the CRT surface.
    The coatings on most of the CRT's and LCD panels, are damaged from not
    properly cleaning, and people touching them with their fingers. Once
    damaged, the surfaces are not repairable.
    The solution is to change the CRT, but this is not going to be practical
    even if you can find a new CRT.
    JANA
    _____
  3. Dirty trick is to fil them with silicone grease or another substance
    with the same refractive index. It effectively renders them invisible
    Andrew
