phillips television set
Discussion in 'Electronic Repair' started by David W, Dec 7, 2003.
  1. David W
    David W Guest
    it is a phillips 26CEI1991.
    i previously posted this msg;
    i didnt worry about the set for a while and decided to turn it on
    hopeing that it would work fine. it surprisingly did and didnt have the
    screen go blue with the raster lines. but 2 days later the problem cam back.
    if i turn the set off for a second then on again i can see a picture but it
    is covered with blue and the raster lines again. the picture fades away
    leaving only the blue screen and raster lines visible. if the set is turned
    off for a while the picture is normal but like before it comes back.
    if anyone knows a soloution it would be muchly appriciated. thankyou.
  2. David
    David Guest
    You need to troubleshoot the blue video driver stage and the crt blue gun
    circuits to determine the cause of the problem. Just some very basic tv set
    troubleshooting needed here.
    David
