Phillips question.
Discussion in 'Electronic Repair' started by Rono, Sep 18, 2005.
  1. Rono
    Rono Guest
    Main board replaced, due to smashed original, now
    plug it in, unit comes on, & you have to unplug to turn
    it off. Works fine, but "F" in top right of screen..."factory"
    mode. Talked to Tech in Ontario, tried all his suggestions,
    like holding vol up, channel down...etc, etc...! He's not
    sure, nor are his co-workers up there. Replace the EEPROM
    with the one from the damaged original board? Rono.
  2. Andy Cuffe
    Andy Cuffe Guest
    A model number would help. You probably need to use the factory
    service remote to exit factory mode. I don't think you can do it with
    the regular remote and service menu. Swapping the EEPROM from the old
    board would probably do it and you also won't need to make as many
    adjustments to the new chassis.
    Andy Cuffe
    <-- Use this address until 12/31/2005
    <-- Use this address after 12/31/2005
  3. Rono
    Rono Guest
    Thanks andy, I don't have the model, it's at work.
    I'll check it Monday, & post it. Rono.
  4. Rono
    Rono Guest
    Replaced EEPROM, works fine. Rono.
