P
Peter Clifton
Hi, I would like to enquire if anyone can give me some advice about a repair
I did for a friend recently.
The TV was a Philips 14PV182/05, which had a tripping powersupply.
I tested most of the electrolytics with my ESR meter, and supprisingly they
all read good.
I tested the HOT -> good, but the set worked with it removed. (Sound + VCR)
I isolated all the secondary supplies derrived from the LOPT, but the set
still tripped (HOT in place).
So I presumed a faulty LOPT. This was confirmed by rudimentary ring testing
on my oscilloscope.
I replaced the LOPT with an HR equivilant, and the TV now appears to be
working fine. My question is, weather I should be looking for an underlying
cause for the original LOPT to fail. I did notice that there was some high
frequency sound coming from the TV (Audible with the TV volume turned right
down, and the cover off) - after I replaced the LOPT. This makes me wounder
if everything is A-Ok, but I'm aware that transformers / capacitors can
sometimes make some noise when running normally.
Do LOPTs just fail on their own, or are they usually 'caused' to fail by
another part? I've seen a cople of references to similar symptoms in this TV
(PSU tripping) being fixed by just replacing the LOPT.
Please note that I don't do this for a living or anything, I'm an electronic
engineering student, and only have a few years worth of experience fixing
the odd monitor / TV / SMPS etc. My theoretical knowledge isn't too bad (I
think), but I lack the experience of someone who comes across these faults
day after day.
Thanks for you help
Peter Clifton
all read good.
on my oscilloscope.
day after day.
Thanks for you help
Peter Clifton
